Originally posted by Turion
I do see the similarities and your post helps greatly to make this slightly less convoluted but on the whole it would be better if we could make this explanation less likely to require an interpreter of nuclear physics. If nuclear spin theory is correct then it is probable that this is an accurate assessment of cause and effect and if so it seems testable with the available data.
"A Constant magnetic field is imposed on a ferromagnetic material"
The Alexey is using a paramagnetic material (*Aluminum) and may be creating a quasi~ferromagnetic effect as the "constant magnetic field" rotates beneath it.
"The oscillating magnetic field supplied by square wave pulsed microwave radiation in the vicinity of 3000 Mhz"
Evidently the paramagnetic effect can produce this pulsed magnetic oscillation and perpendicular to the charged aluminum plate, and causing the whole to fall in to a NMR.
